[Pro] Highslide
The flash carousel on Dave Owens site www.ineedwebhosting.co.uk is wonderful.
On the developers site for that carousel is a program called highslide. This looks like exactly what I need to do for a client. Is there any one that knows how to intergrade this with FW5?
I spoke to the designer - never heard of FW - but if we can get it intergraded he will help to connect it with carousel.
Thank you for all your help and patience
The correct link is:
www.ineedwebhosting.co.uk/blog/how-to-add-a-flash-carousel-in-freeway/
There are also these other lightbox effects to look at also:
http://www.cssdrive.com/index.php/news/resources-cat/C51/P20/
wonderful.
David Owen :: Freeway Friendly Web hosting and Domains ::
http://www.ineedwebhosting.co.uk :: http://www.ineedwebhosting.co.uk/blog
hi there swimmer35,
I have integrated highslide into a site I am currently working on. It is not complete as yet, but it does utilise highslide, and was put together in Freewy Pro 5.
Because the site is not live I cannot publish the URL here, but if you want to send me a private email, I can send you the link directly.
Best,
Craig
Craig,
I emailed you through my private addy
Thank you again
Julie
hi there swimmer35,
Best,
Craig
I have created a sample carousel with highslide by modifying David’s Freeway file (hope you don’t mind me using your file as a starting point David).
I used the code available at - http://www.flshow.net/carousel/highslide/ and incorporated it into the Freeway file.
It can be downloaded from - http://sn.im/die9k-y60
Craig
You are amazing!!!
Thank you
ps - so are the rest of you that are helping me!
point David).
Craig
You are very welcome :wink:
While I work on this - is it ok to email you with questions?
where do I put highslide for local use (for when I work on it on the
laptop?
sounds stupid - but since its not a program… etc…
For local use, you can just leave it in the site folder where it is in the sample I sent over.
Of course, feel free to email me with questions, but I may not be able to answer right away as I have some meetings this afternoon.
regards,
Craig
I know this sound silly -
but I looked at your folder in preview and I saw the carousel but not
the highslide…
I clicked on the pix to see it open and it did not.
I will try step by step in afew (when my daughter is napping LOL) -
but I wanted to touch base aobut that.
regards,
Craig
Don’t worry, we’ll get you up and running.
The highslide folder should be in the same folder as your HTML file which Freeway exports, so if the highslide folder is not there, just copy the one from the file I sent over and put it in the same folder.
Folder Structure should look something like this:-
 Site Folder
    css (folder)
    default.xml
    highslide (folder)
    images (folder)
    index.html
    pngbehavior.htc
    Resources (folder)
    swfobject.js
Craig
Right now I am just running yours to test it -for final look.
and when i run it - i get the carousel without the highslide.
As I understand from the website - you can click on the pix it will
expand (in a small pop upwindow) with a caption - thats not happening
when running yours …
I do appriciate this
Site Folder
   css (folder)
   default.xml
   highslide (folder)
   images (folder)
   index.html
   pngbehavior.htc
   Resources (folder)
   swfobject.js
Craig
That’s strange, it’s working locally here.
I have uploaded the very same folder online at:-
http://files.cpfusion.com/carousel/index.html
Let me know if you can see it working now. It may be something to do with javascript not running locally on your computer.
Craig
it works there…
what can i do to solve that?
Craig
Which browser are you using?
I have both firefox and safari
And is it doing the same in both browsers?
I have tried in both Safari and Firefox and both work with me locally. Are you positive you are loading the index.html file from the “Site Folder” from the file I sent over?
If you are previewing the site from within Freeway, have you checked to see if the highslide folder is in the same folder as the published HTML file.
If eveything is where it is supposed to be then I’m stumped, does anyone else have any ideas?
This is the message I am getting - sorry about the jpeg - could not
highlight apple c the info
I uploaded your file up to my test site
www.grdesigns.net/testsite
this is what I have under my public_html
the red is what I uploaded
ftp://72.29.84.123/public_html
ftp://72.29.84.123/public_html/_blank.gif
ftp://72.29.84.123/public_html/cgi-bin
ftp://72.29.84.123/public_html/clients
ftp://72.29.84.123/public_html/clients.html
ftp://72.29.84.123/public_html/contactus.php5
ftp://72.29.84.123/public_html/css
ftp://72.29.84.123/public_html/easiForm_config.php
ftp://72.29.84.123/public_html/easiForm_license.php
ftp://72.29.84.123/public_html/easiForm_mail.php
ftp://72.29.84.123/public_html/easiGallery_license.php
ftp://72.29.84.123/public_html/effectivecommuni.html
ftp://72.29.84.123/public_html/examples.html
ftp://72.29.84.123/public_html/highslide
ftp://72.29.84.123/public_html/index.html
ftp://72.29.84.123/public_html/ioncube
ftp://72.29.84.123/public_html/iphoneapp
ftp://72.29.84.123/public_html/Resources
ftp://72.29.84.123/public_html/services.html
ftp://72.29.84.123/public_html/testsite
ftp://72.29.84.123/public_html/testsite/_blank.gif
ftp://72.29.84.123/public_html/testsite/css
ftp://72.29.84.123/public_html/testsite/default.xml
ftp://72.29.84.123/public_html/testsite/images
ftp://72.29.84.123/public_html/testsite/index.html
ftp://72.29.84.123/public_html/testsite/pngbehavior.htc
ftp://72.29.84.123/public_html/testsite/Resources
ftp://72.29.84.123/public_html/testsite/swfobject.js
PS - since the red did not go through - everything under the /
public_html/ testsite
