Aha,
The “highslide” folder should be inside the “testsite” folder. Currently it is at the root of your public_html folder.
Craig
Aha,
Craig
that worked!
ok now to build / rebuild the one on the other site
I need to then put highslide in that folder too?
On Mar 10, 2009, at 2:47 PM, Craig Paterson wrote:
Aha,
Currently it is at the root of your public_html folder.Craig
Yes indeed. That is the easiest way in this instance.
Craig
The page I went to for installation is:
http://highslide.com/#installation
I don’t see any steps that coordinate -
the other page I looked at was:
can you give me a link to these instructions that corrilate with yours?
TY
J:)
Craig
ps should I be doing this within the site I did the carousel or should
I have a fresh page?
Craig
Julie,
You should be able to just copy that highslide folder into any new site you create. You must however make sure that the highslide folder is within the folder where all your site files are. So if the site was all in a folder called “newsite”, the highslide folder should be inside this folder.
Normally you would only have one highslide folder per website (as shown on the http://highslide.com/#installation page), but when testing - like you currently are - each test site folder should have its own highslide folder within it.
The tutorial page shows you the many ways to make changes to the way that highslide works within your site. Highslide is an extremely customisable piece of code. There are many customisations which may be made, I have only scratched the surface myself on sites I have used it on, and the latest version (4.1 due out soon) adds even more features.
Craig
Thank you so much…
I am still having problems finding the steps you were referring to…
my next venture is the pop up areas like you have…
good luck on your project!
On Mar 10, 2009, at 6:30 PM, Craig Paterson wrote:
Julie,
should be inside this folder.Normally you would only have one highslide folder per website (as
its own highslide folder within it.The tutorial page shows you the many ways to make changes to the way
features.Craig
Hi Julie,
Do you mean can I provide a link to show you how I have changed the style of the highslide pop-up on my test site?
If so, then there are loads of areas of the Highslide website which offer help in modifying the way highslide looks and behaves.
I always start at the support page - Highslide JS - JavaScript thumbnail viewer
But to find out most things you want to change, you really need to be looking at the API Reference - http://highslide.com/ref
For example, if you want to change the colour of the borders which appear in the highslide pop-up (like I have done on my test site, and also here - http://www.williamlockie.com/stock_service_ladies_classic.php, click the “view available colourways” link or any of the left hand side footer links"), you should then follow the instructions on this page carefully - http://highslide.com/ref/hs.outlineType
There is a lot of information on these pages as highslide is a very customisable piece of code, and I have found that the developer - Torstein Hønsi - is very good at providing help on the highslide forums, as are the other members of the forum. So if you get really stuck with a specific highslide question and can’t find it in the support page, tutorial or reference, then post a question on the forums as you usually get a pretty quick answer there too.
Hope that helps, and good luck with your project. I had another look at your test site, and it seems you have managed to progress quite a bit since last night. Hope you get the vertical navigation sorted out.
Craig
Thank you for all of your help.
vertical navigation??? forgot about that
thank you for the links I will look at them when I get home from work .
Julie
to…my next venture is the pop up areas like you have…
Hi Julie,
style of the highslide pop-up on my test site?If so, then there are loads of areas of the Highslide website which
offer help in modifying the way highslide looks and behaves.I always start at the support page - Highslide JS - JavaScript thumbnail viewer
be looking at the API Reference - http://highslide.com/refFor example, if you want to change the colour of the borders which
page carefully - http://highslide.com/ref/hs.outlineTypeThere is a lot of information on these pages as highslide is a very
forums as you usually get a pretty quick answer there too.Hope that helps, and good luck with your project. I had another look
bit since last night. Hope you get the vertical navigation sorted out.Craig
