On 16 Jul 2010, 4:38 pm, waltd wrote:
Okay, I can see what’s happening there. I need to fix the Action so it
matches up with the documentation, but until I do, you can fix this by
clicking once on each of the image “headers”, setting them to Align
(float) left, and publishing again.
On Jul 16, 2010, at 12:20 PM, Mr worm wrote:
Link:
http://www.edwardlawlor.co.uk/2010/accordion.html
On 17 Jul 2010, 1:00 am, waltd wrote:
There’s a new version of ScriptyAccordion on the Forge with this fix in place. It works no matter if the elements are set to float or not. (They end up floated after the action runs now.)
Just downloaded it and replaced my old actions, so less tweaking now. Thanks Walt.
Although it works fine, it is really messy and requires a bit of trickery to get my desired look.
http://www.edwardlawlor.co.uk/2010/accordion2.html
The example below is as close as I can get. My only issues are can i apply ‘easing’ to this action to make the accordion move smoothly?
This accordion is currently set to ‘click’ to open each tab, although mouse over is a little jumpy, especially because of how this animates.
Also when the accordion animates it leaves a blank space at the end (which the last element in my accordion fills once opened) So currently I have placed a DIV in the BG to highlight this (black) it also makes it look neater I think! This is also initially covered up as I set the first tab to be open as opposed to closed.
I’m assuming to make this Accordion work like the initial examples I provided involves a lot more work! Shame as I think I’m half way there in getting the Phatfusion e.g. to work!!! so close!
I’m still playing with options to make this look as visually ‘Fluffy’ as possible, any suggestions you may have Walt to make this better I am open to!
Many thanks
Worm
