[Pro] hover effect possible in Freeway?
On www.billingsapp.com an html-item appears when hovering the download button.
Does anybody know how this is done in Freeway Pro? Perhaps there is some action capable of producing this kind of hover effect? Thanks in advance!
Best regards,
Rogier
Good morning, lets see if I paid attention…
wouldn’t a spawn new window do this…
unsure how to get the pointy part at the bottom… but you can ad an
outline …
Julie
download button.
in advance!
Best regards,
Rogier
Try using a Show/Hide Target Layer Action instance. Draw your “tool-tip” as an HTML box, style it and add your content, then apply Show/Hide Target Layer to it. Set it to Indigo 1 in the Actions palette, and set its visibility to Initially Hidden. On the part of your page that you would like to use to “trigger” this effect, apply an instance of the Rollover Action. You don’t need to assign any sort of rollover effect, you’re just using it to provide the signal that the rollover event has happened. Set that rollover to trigger Mouseover Indigo 1. Preview, and see if this does what you want.
Here’s a way to do the pointy bit without any additional graphics: http://freewaytalk.net/thread/view/48670#m_48670
That’s it Walter! Inside the html-item I’ve placed an inline transparent png which has the pointy thing at the bottom. It works perfectly.
Thanks a lot!
Best regards, Rogier
