This is going to take some hand-edited CSS, and you won’t be able to
see the effect of it in the design view – only in the Preview or a
browser.
You could create a style in your Styles palette with this un-lovely Tag:
.mooFaqHref:hover
and absolutely nothing in the Name field, and apply a background color
to that style. Problem here is that the way this element is laid out,
the only “hot” part of the link will be a tiny box shrink-wrapped
around the letters of the link text.
You could try adding another style with the Tag:
.mooFaqHref
and again, nothing in the Name field, and use the Extended dialog in
the Edit Style dialog to add
display
block
as a Name and Value for an attribute of that style.
But that might blow up your layout, because there looks to be a lot of
padding in the surrounding P (style10) which is going to press in
against the link. If you remove all of that padding, and add it to
the .mooFaqHref style itself, then you can have a big fat link that’s
easy to click, and your mouseover highlight will be the entire size of
the “tab”, too.
On Apr 23, 2010, at 5:25 AM, neil.west1 wrote:
http://www.thinktankcd.com/Test/Stowasis/choosing-your-feature.html
On this page you can see 4 navigation menus, 3 of which we are
currently playing with.
The main menu to the left is a standard CSS menu with drop downs,
but the client doesn’t like the way they pop out to the right, so
we’re now looking at accordions using moo tools.
Menus 2 and 3 are both accordions built using html items in 2
different styles, but the question with both is how do I show a
rollover to indicate the user is hovering over an item?
Any suggestions?
Neil
