[Pro] how can I edit a rollover ?
I created a rollover with graphic text . I am trying to go back and change the color of the bottom image
and I can’t seem to figure out how to do this. I unlocked the images and can edit the top one but cant figure out how to get to the one underneath the top one to make the change.
Thanks for your help!!
There’s a few different ways to do this. One of the simplest is to let
the Action help you. Click on the top image and look in the Rollover
tab of the Actions palette. If you’re on the Parameters segment, click
on Images. You should see a spreadsheet of the images involved in the
rollover. Click on the name of each image in the left (vertical) axis,
and each image will highlight in the layout as you do. You will be
able to access the color properties through the Inspector once you’ve
selected the image. To edit the text in the “hidden” box, simply
select it as above, then hit the Return key on the keyboard to enter
the text editing mode. Freeway will “jump” that element to the top of
the stack (temporarily) so you can edit the text inside it.
thanks for taking the time to share that.
The only part that it lets me edit is the top one.
Maybe I did something strange in the way i set up this rollover (but it works) . I am dyslexic so I might be missing something in your instructions . When I click on either image (via that rollover palette ) I am only able to select and edit that top one still . I cant seem to access the bottom one .
Thanks for trying to help me.
Try selecting the Rollover in the Site Panel on the left of your
screen. You can select each state separately and change the colour in
the Inspector and if you hit Return, (as Walter said) you can change
the text. If you have an image, you can change this by going to the
‘Item’ menu and clicking on ‘Modify’.
Colin
Hi Colin& Walter ,
YES!!! DUH that’s it . It was the “HIT RETURN” that made it work!!! I read it and it did not compute the first time .
Thanks!!!
Sue Z
