My gallery page has been coming up as my main page. Also my main page is not labeled index_html. How can I easily change this.
You can change your ‘main/home’ page in the inspector were it says File: and of course it should be index.html
You will possibly have to rename your gallery ‘index’ page to something else or place the gallery in a folder of its own and reference it within that. ie. ww.mysite.com/gallery/index.html
s
The point being that you cannot have 2 pages with the same file name in a single folder and FW will rename one of them ie index.html and index2.html
So firstly change index.html to gallery.html and then change the page you want to be your index.html page
FW will automagically update any links you have created between pages.
