(Freeway Pro 5.5)
I’m wondering if I can do the following, and how I’d go about it. It looks like the iFrame Action might be part of it, but I’m not totally sure.
What I’d like to do is this…
One item contains a scrolling list of events - dates and a brief comment. If you click on an event, the detailed information appears in another item to the side (this is probably an anchored point in a single scrolling list as I think this will make it easier to update the diary by simply replacing the linked html file on the server). If you click on the detailed event, a Google maps Action shows the location of the event.
There’s a few things here -
- How do I change the colour of the scroll bars? I seem to be able to only get a grey scroll bar in a white area at the moment. It’s a bit ugly!
- How do I get the outgoing anchor link to cause the relevant text to display in the second item? (This is where I thought IFrame might be useful, though that appears to link to separate html files rather than to a location in a longer file)
- How do I send a specific location to the Google Maps action?
And there may be more things I need to know!
Thanks for any help.
