Also in case anyone did not know about these neat Freeway tips when
working with box model sites…
You can use spacebar-drag to move items from inline object to inline
object to absolutely position items within inline divs (you can use
the site panel item view also to drag items).
And also pixel nudge items to “hang them” outside an inline object ,
giving a negative px positioning.
These make designing and managing inline box model sites easier and
more creatively. i.e. you can place some items in the normal drag and
drop manner (using space-bar) and work in a full box model site. And
keep the best of both worlds.
On 10 Mar 2009, at 00:23, chuckamuck wrote:
It seems that it is impossible to alter or add something down the
line if needed. The layout seems pretty set in stone.Not true. You can use cut and paste to move html boxes around. You
just have to keep track of how your boxes are put together.Try starting with a very basic layout grid first; one overall page
box with header, body, and footer boxes inside that. Then put all
relative content (other html boxes, graphics, tables) for each
section into the appropriate box. Change the content, not the grid.
Keep your “grid” boxes set to a fixed size until you have all the
pieces in place, then you can go back and set heights to shrink for
the grid objects.
David Owen :: Freeway Friendly Web hosting and Domains ::
http://www.ineedwebhosting.co.uk :: I Need Web Hosting Mac friendly web hosting and domain registration
