Is there a way to collapse all the items in the site panel? ie, rotate all the triangles to hide sub-entries?
Hi Joel,
Have you tried clicking the triangles with the cursor? They are “open” by
default, but clicking them should rotate them closed. After you save and
close the document, the triangle “position” should remain as last left.
That’s my experience with the subject, anyway.
Hi Ernie.
Yes, I see that clicking a triangle collapses that topic, and yes I think they are all open by default. That’s why I was looking for a shortcut to collapse all of them at once to be able to see the top-level topics only – something like shift-click on one triangle to collapse them all. Nothing seems to do that.
Hey Joel,
Your original post didn’t say “all at once” or else I would have said “that
is impossible”.
Don’t blame the messenger
On Friday, May 24, 2013, Joel Nisson email@hidden wrote:
Hi Ernie.
seems to do that.
Option-click collapses all nested items.
