Hi,
I wonder if it’s possible to import/download my old homepage (made by a graphic designer) in to Freeway Pro, so I can start there, and don’t need to do everything from scratch.
Peter
This may not be the answer you are looking for but have a look at this. http://www.softpress.com/kb/questions/40/Fast+Way+to+Recreate+a+Website
The other thing to take into account, and without seeing it we don’t know, if the site was created graphically then it may be just a case of importing the graphics into FW.
You could post a link and we can have a look.
Hi David
www.mansklig.se
Peter
Nothing difficult here.
Start with a new Master page at the correct size
Download and reuse your graphics along the top for the header.
Create a CSS menu full width.
Then create a new page using that master. Welcome page will automatically have the file name index.html but you will have to add the title. The Mansklig heading is a graphic so can be downloaded and reused.
Copy/paste other text and style.
Repeat for the other pages.
Go back to the master and add the links to the CSS menu text.
And that is really it.
I will try it
Thanks a lot!
Peter
Just to show you that it can be done quite easily and quickly
http://www.deltadzine.net/peter/index.html
Now the way it was originally constructed is not the way I would do it but here it is made the same way.
and of course I’m curious about how you should have done it…
I understand I have a lot of possibilities to improve my home page through Freeway Pro
If you want you can have the FW Pro file as a starting point - you will find my email address in the People section
