[Pro] how to reestablish menu links
By mistake I started to change the menu buttons on a particular page instead of the master page.
Now when I update the mater page, that particular page
I messed around with does not update. Is there a way to reestablish the link to the master page menu buttons?
Hi Bob,
With the item selected you should see two checkboxes in the first tab of the Inspector palette; ‘Use Master Content’ and ‘Use Master Settings’. Re-enabling both of these will reset the item back to the same state as the item on the master page.
Tim Plumb
Creative Director
E: email@hidden
Freeway: You create, it codes
Thanks Tim!
While you’re here, do you mind if I ask about a problem I just ran into and hope it’s something that can be corrected.
I just uploaded my first site yesterday, (on a mac) and everything looks great. I just went and looked at my site on a PC and the entire site is reduced in size to about 25% of the screen. Is there something that I need to do in Freeway Pro to remedy this?
thanks,
bob
Hi Bob,
What is the site address? I’ll take a look on my Windows laptop.
Tim Plumb
Creative Director
E: email@hidden
Hi Tim,
My site is
designsongolf.com
Most appreciated!
Bob
Hi Bob,
I’ve looked at the site in IE8 on my laptop and using IE Net Renderer (http://netrenderer.com/) and the page appears very similar to the site I see in Safari and about the same size. It may be worth contacting support with a screen shot displaying the differences you are seeing;
Softpress KnowledgeBase :: Softpress KnowledgeBase
On 13 Mar 2012, at 16:33, bob wrote:
My site is
designsongolf.com
Tim Plumb
Creative Director
E: email@hidden
Hi,
Sounds like your PC resolution is not appropriate.
Omar KN
Thanks for taking the time to help!
