Hello all,
A graphic designer is doing a new custom made font for me.
Where would I import this new font type to so it appears on my list of fonts in Freeway?
And does anyone know what the new font should be formatted to in order to work in Freeway ?
If you want to use this font in Freeway for graphic text, then you simply install the font on your Mac in the usual manner. If you use a third-party font library management utility like FontExplorer or the like, then use that application to install it. If you use the Font Book application that comes with Mac OS X, then use that.
If you want to be able to use this font as a Web font, and embed it in your HTML pages so that other users can see it as you designed it, then you first need to ensure that you have the Web rights to the font. Next, you’ll need to use a conversion utility or service to turn it into the Web font format, and an Action or JavaScript library to apply it to your pages. Paul Dunning’s Caxton Action is one of these approaches, and you can read more at his site. http://actionsworld.com
On Nov 3, 2011, at 9:17 AM, spiros wrote:
Hello all,
