To an english speaker it is wrong but as your target audience is Dutch you are forgiven
This error suggests that you used Apple TextEdit and saved an RTF file rather than a plain text file. Note the backslashes that I presume you did not type, and the reference to cocoartf.
In TextEdit, there is a Convert to Plain Text menu option. When you do that, the font will change to a monospaced console font to indicate that you are truly saving text, not styled text.
I heartily recommend the free and very powerful TextWrangler editor from http://barebones.com in place of TextEdit for any programming needs.
On Jan 28, 2016, at 10:57 AM, Erik email@hidden wrote:
Hi Dave,
I typed your code in a new text editor page and saved it to my server as .htaccessRewriteEngine On
RewriteCond %{HTTP_HOST} ^graphicid.nl [NC]
RewriteRule (.*)$ http://www.graphicid.nl/$1 [R=301,L]But again a new error (blanc screen internal server errror;
[Thu Jan 28 16:44:31 2016] [alert] [client 66.249.93.28] /var/www/vhosts/50/208707/webspace/httpdocs/graphicid.nl/.htaccess: Invalid command β{\rtf1\ansi\ansicpg1252\cocoartf1348\cocoasubrtf170β, perhaps misspelled or defined by a module not included in the server configuration
On the same server at cms.graphicid.nl it is ALSO NOT working but I donβt get an error here?
