Is there a way to show the html code for a page, or form on a page in 5.5 Pro? I’m new to Freeway, but I’ve used Dreamweaver in the past and it has an entire window showing the page code. I want to add a “required” html code to the customer email area on the form. Or can someone tell me how to do that? The Knowledgebase leaves much to be desired in this area. Thanks.
There are various ways of adding code to a FW page ie Insert>Page Mark up or Page>HTML Markup but depending on the code will determine the best way to add it.
I have a form setup and I want to require the applicant to type in their name and email at the very least or they go to the error page. The form in setup inside a table to keep things organized whether on Mac or PC.
Got any ideas which is best, Insert>Page Mark or Page> HTML Markup? And how to I get it to apply to just the Name" and “Email” text areas of the form only?
There’s an Action you might try, called Validate Suite, I think. Here’s a “canned” search on ActionsForge that ought to turn it up for you: http://actionsforge.com/find/validate
Thanks. This should help me. Also, great example for me David, I really appreciate all your help guys. Hopefully I’ll be able to repay the knowledge favor in the future.
