I’m putting together a simple html email. It renders great in Safari, but in Firefox I’m getting a mysterious white border showing up at the right edge of my header image.
Looking at the code, it seems Freeway is turning my header area into 2 columns: one 560 px wide and the other 1 px wide. This is my best estimate as to the cause, but I’m not sure how to fix it, as FW is generating this column on its own.
Try turning off the “Reinforce layout tables” option in the Document Setup dialog, output pane.
And like magic, the problem is solved! Thanks, Walter.
I have to say that I’m usually fairly afraid to touch that checkbox, as I figure it’s adding hacks to make the page more compatible. In this case, I guess the opposite is true
