This is my first try at web design and I’m completely stuck here.
I have used the show and hi Layer action
Which works perfectly well until I add the HTTP S to my webpage then the action stopped working
I can see why this is but cannot find the JavaScript file to change the link from HTTP to HTTP S.
Or maybe I am doing something else wrong any help would be appreciated Best regards Daniel James
The issue is the Show/Hide Layer Action. It is coding an absolute link to the http address to the Google CDN for the Prototype and Scriptaculous libraries. The browser is (properly) refusing to load that since the schemes don’t match. You can use this Action without them – all you have to do is switch the Effect picker to None, and the libraries will not be used. The image will “snap” into view rather than fading in.
On Nov 5, 2013, at 5:43 AM, danieljameslondon wrote:
Hi hope someone can help me
