How do I find the Div code so i can copy?
watch this episode starting at somehow 5.30 (the things before is a cliffhanger of the previous episode):
http://www.kimmich-digitalmedia.com/videos/016_the-coding-episodes-part9-structuring-content
It’s about DIV which is the rendered name of a HTML-item in Freeway terms - or literally the green rectangle wrapping content.
As a novice, I highly recommend to have a deeper look into the manual. Just to get used to basic terms of the app and its behavior.
You’re the one with the template, as far as I remember? Water on my mill cause I’m the one that says, “Templates” and Freeway don’t fit together.
Whether you know what you’re doing and you don’t need one, or you don’t know what you’re doing so it’s useless.
Just a Tipp:
Use the Template as is. Just to get used to it. Once you’ve got the gist, work further. WebDesign is a profession requiring professional attitude and profund knowledge these days.
On 12 Nov 2015, 10:44 am, Thomas Kimmich wrote:
…WebDesign is a profession requiring professional attitude and profund knowledge these days.
Much wisdom in that statement. I’ve used Freeway for 11 years. But at my age (72), available time, and fuzzier brain, I can’t get deep enough into the “profound knowledge” Thomas is referring to. So I keep it simple, and it works. Example: the website in my footer below.
