Hi when user clicks the accordian the spacing goes inbetween the rules and headers. As Waltd suggetsed I added space before and after in the headers styling and same for the HR tag but no luck…
One thing to try would be to get rid of the HR, and use CSS to style a
similar rule at the bottom of your P or the top of your H2. I don’t
think that the existence of that element is what’s throwing things off
per se, but I would want to rule it out. IE is such a tender, fragile
flower, so unsure of itself in the great wild Web. It’s hard to say on
any given occasion what will make it start muttering to itself in the
corner.
Open up your H2 style (the one you’re using inside your accordion) and
add the following rules to it using the Extended dialog. For each
rule, use the New button to add, and then put the part before the : in
the Name, the part after in the Value, and leave the : out altogether.
padding-top: 12px
border-top: 2px inset #666
You’ll have to fiddle with the border color – using inset causes it
to create a highlight and a shadow color based on the color you set,
so look at it and see what you like. Also try a 3px inset, that might
be even better for you.
On Apr 16, 2011, at 3:34 PM, Justin Easthall wrote:
Actually It seems to work 80% I just retested it. I think this could
be ok? How do I add a CSS HR in Freeway? I no nout about this or the
code!
I’d just need code to make a two pix rule with top grey, bottom pix
white
I think I could figure this out if I know how to add the CSS?
