Lode_Rosel
(Lode Rosel)
January 17, 2012, 11:04pm
1
Hello,
Testing my site on “IE8” SNW is not working most of the time; returning this error:
Object doesn’t support this property or method:
scriptaculous190packer.js
Code:0
URL:http://www.dierendorp.be/resources/scriptaculous190packer.js?load=effects
Thanks, Lode
Where should I be looking?
I dont see any links on that page http://www.dierendorp.be/
Lode_Rosel
(Lode Rosel)
January 17, 2012, 11:50pm
3
Hi,
page “team”’ click on little picture on the right. (not on the name)
Clicking on the “apppering buttons” top left gives a second snw.
Password is : Dierendorpindex
Thxs, lode
Lode_Rosel
(Lode Rosel)
January 17, 2012, 11:53pm
4
Edit :
http://www.dierendorp.be/team.html
Site is far from live, still testing
lode
They all work for me in IE8 but Patsy looks like it is not the iPad friendly setting.
And I think it is a bit OTT having 1 SNW within another and then a Showcase too - asking for trouble.
Lode_Rosel
(Lode Rosel)
January 18, 2012, 12:11am
7
That is correct, I changed “Patsy” to see what result this will be in IE8 (parrallels). I see my client today, and they all work on PC’s, I let you know, thanks, Lode
Lode_Rosel
(Lode Rosel)
January 18, 2012, 12:24am
8
I’m still looking for the best way to present the images. Funny, that the second SNW works perfect in IE8.
Bye, Lode
Paul4
(Paul)
January 18, 2012, 9:24am
9
If you are using Freeway 5.6.2, you need to download the latest version of the SNW Action. Freeway 5.6.2 sees a change with the versions of Scriptaculous that is loaded, and if you are using an older version of my Action, you will get both the old and the new versions of these libraries, which may cause problems.
http://www.actionsworld.com/Actions/SpawnNewWindow
So your first step is to download the SNW Action, republish and see if that does the job.
Lode_Rosel
(Lode Rosel)
January 18, 2012, 6:55pm
10
Hi Paul,
Ok, will do that. Keep you posted.
Thanks, Lode
Lode_Rosel
(Lode Rosel)
January 19, 2012, 12:05pm
11
Hi Paul,
I installed new versions SNW and FW. I noticed already an improvement in IE8.
A few problems with “nested” SNW and extra actions:
“Action close window”: results in: Windows can’t find “javascriptiframeHide”, closing nested SNW with the closing button (X) results in: “Windows can’t find javascript”.
Maybe, as Dave suggested, it is a little OTT and I’m looking for “trouble” ;-)). But I like the “cleanliness” from SNW.
Works fine with Safari/FF on windows 7 (Parallels) and of course on the Mac.
see page: http://www.dierendorp.be/team.html
(As my client as IE9, I did not see any problems)
Quick question, as I’m still working on it, should be a good idea when the site is finished, to remove all the files from the server and upload it again?
Thanks, Lode
Lode_Rosel
(Lode Rosel)
January 19, 2012, 12:21pm
12
edit
I have been to fast, “FF” Mac and Windows: “nested” SNW doesn’t close when clicking on the closing button; returns a “blank” page.
(Mac) Chrome works fine, Opera returns: javascript:iframeHide();
Maybe I need find a way around it.
Bye, L
Paul4
(Paul)
January 19, 2012, 1:27pm
13
I think nesting them is going to be asking for trouble from a user stand point anyway.
Lode_Rosel
(Lode Rosel)
January 19, 2012, 1:53pm
14
Ok, thanks for the advice and help.
Is there a way to make “SNW iPad Friendly” move around on the screen like the “SNW Normal”? Or to get rid of “top bar”?
Thanks, Lode
Paul4
(Paul)
January 19, 2012, 4:40pm
15
No. It’s a fixed entity, and no plans to make it moveable either.
