Is your own site (the one that holds the iframe) using https (secure) protocol, or regular http? If you follow this link, what do you see:
http://www.mixcloud.com/widget/iframe/?embed_type=widget_standard&embed_uuid=175a634d-fb1d-4297-b10c-bbb019dacda1&feed=https%3A%2F%2Fwww.mixcloud.com%2Fslaggbrothers%2Fthe-slagg-brothers-6-towns-show-5315%2F&hide_cover=1&replace=0
When I follow that, I get redirected to https:// and I suspect that may be part of the problem. If you refer to secure content in the context of an insecure page, you may get an error. I’m not sure if an iframe can solve that basic problem or not.
I tried making a test page here, but I am getting a missing file error from the JavaScript:
Failed to load resource:
https://www.mixcloud.com/media/sourcemaps/player_widget_js.1a025715fbd421ad42a36c1aba24a3c6.js.map
the server responded with a status of 404 (Not Found)
That could be because I am not hosting this at the correct URL for your license key.
I am out of ideas here, though.
On Mar 5, 2015, at 2:14 PM, Noel Sergeant email@hidden wrote:
So is something wrong with the code?
This is the full code (I normally just use from the first ‘www’ to ‘cover=1’
Strangely, if you click on ‘Slagg Brothers’ towards the end of the code it gets the correct link. Do I need to copy a different part of the code?
The Slagg Brothers 6 Towns Show 5.3.15 by Slagg Brothers 6 Towns Radio on Mixcloud
