[Pro] iFrame formatting
I’m trying to format an HTML item with iFrame action to consistently fit 90% page width. When previewing in the browser, the frame sticks to the left of the page, not stretching.
How do I fix this?
Could you post a link to the page where you are seeing this issue? It’s difficult to diagnose without seeing the generated code.
How do I fix this?
here you go
The width is displaying 304 px rather than a desired percentage of the page
Further, the iframe is positioned absolutely rather than inline, which means that when I add a line of CSS to the page to scale it up, the text describing the iframe overlays it, rather than scooting out of the way.
To see what I mean, open the Page / HTML Markup dialog, move to the Before section using the picker below the text field, then paste in this code:
<style type="text/css">
iframe { width: 100%; height: 500px; }
</style>
Preview in a browser and you’ll see things crashing into one another.
The way around this is to use an inline layout (at least for this part of the page). Draw a box full-width, then set its width to 100% (using the Dimensions part of the Item Inspector). Double-click inside this item, so you see a flashing text cursor, then choose Insert / Action Item / iFrame from the menu. Make the URL, border, and scrolling settings, drag the box out to the width of the parent item, choose a height that works, and with the aforementioned CSS, you should be able to have a flexible iframe. Note that unless the page you inserted into the iframe is also designed in a flexibly-responsive manner, you will potentially have some side-scrolling to deal with when the outer page (containing the iframe) is resized smaller.
Works great, thanks so much for your help
