Using Freeway Pro 5, I cannot iFrame 2.1 to work correctly, though it could be my inexperience to web design. The instructions show that parameters such as alignment and margin can be set, however, those options do not appear in FW Pro 5.4.2.
All I am trying to do is to get links on a page to load separate audio files within an iFrame window within that same page. I am unable the page with the audio file to load within the iFrame unless it is the default page, but the links on the page don’t change the audio file in the iFrame, it just loads a new page. Do you layer different iFrame windows and make them work as a rollover? This should be stupid simple, but it seems I may be just stupid.
