This is quite a long page, if you scroll down towards the bottom and click the like for more information, it takes you to another page within the iframe. The problem is, is that the new iframe window stays where it is and you need to scroll to the top of the window to see the information. This is a problem as users, do not know this and think the page is black.
I understand that there is some code (like: window.parent.ScrollToTop(); // Scroll to top function) but not sure if this is correct and where it should go as I am not technical on the html side of things.
Hope this all makes sense and someone can help as it’s driving me up the wall!
I’ve added a small bit of JavaScript to the iframe so that when it loads the content page it scrolls the parent page back to the top. Simply copy the following code into your Freeway page using Page > HTML Markup > Before ;
<script>
var target = document.getElementsByName("list")[0];
target.onload = function () {
window.scrollTo(0,0);
</script>
The code is a little more complicated that it needs to be simply because there isn’t an easy way to do this if you are using the iFrame Action.
