Is it possible to display an external website within your own Freeway site (similar to the way iFrame works in RapidWeaver)?
How about using an iFrame in Freeway?
k
You can get the iFrame action from here, if you want to use it:
http://www.actionsforge.com/actions/view/99-iframe
-katie
Freeway site (similar to the way iFrame works in RapidWeaver)?How about using an iFrame in Freeway?
k
Thanks - that worked perfectly!
