[Pro] iframes and bookmarks
Walter,
I finally got back to those problem pages today, and it looks like that is going to work, however…
In order for the content page to know where the resources are once the stripped page is incorporated into the portfolio.php page, the paths have to be absolute. (Or I have to remember move the resources from one folder to the local ones each time I republish.) I added a line after the head, and that works great for the graphics, but changes the links, as well. Also, if some resources are being brought in from another folder (page background graphic, for instance,) that also gets changed. Is there some other way to change just the graphic paths without changing the links?
Thanks, David
Use the Remote Resources Action to make all of the paths root-
relative, or use a single Resources folder for the entire site. Either
one should work. Any links that you place on the page fragments should
be made manually, not using Freeway’s automatic hyperlinks, and those
of course you can code as root-relative. This will have the best
chance of succeeding.
On Aug 26, 2011, at 4:12 PM, David wrote:
Walter,
Thanks, David
