I noticed that when you upload your Freeway Pro files using the built-in upload feature ALL of the image files are placed at the root.
Is there anyway to have Freeway Pro place them together in an images subdirectory?
Freeway Pro puts images in a common Resources folder, unless you have some
other option chosen in Preferences. Check your preferences.
subdirectory?
Hey Ernie, I’m not finding the dialog box that controls that.
I checked the manual and I see this option available when you create a NEW document, but how do you set it for an existing document?
Silly me. I found it under File > Document Setup > Output, fourth pull-down from the top. Thanks Ernie!
