[Pro] Importing a site
Any new ideas on how to import a site created in Dreamweaver into Freeway Pro? Thanks!
It’s going to be rough around the edges if you try and use the “Import HTML” as it doesn’t work very well. Your best bet, if not too much, is to re-create it. I’ve tried to take an image of it and setup the guides and all that and it ends up taking longer than it took me to build the original. Again, my opinion, but seems to be the result of many.
If it’s not a huge site it shouldn’t take too long. Also, it’s more the HTML side of it rather than the CSS since you can import a CSS sheet very easily.
Still new at this and sorry for the dumb question but: How do I import a CSS sheet?
If you double click on the “Ay” icon in your CSS palette then you’ll get a pop-up screen with your CSS information and then down at the bottom is a “cog” icon and if you click on that then it has a “import style sheet” option. If you want a picture I can take a screen-cap.
