Fuzzy_Z
(Fuzzy Z)
May 13, 2009, 3:49am
1
How would one go about importing code into a web page in Freeway 5 Pro?
I want to impliment Google Analytics…
Also, how can I enter Meta Tags?
Thanks…
The Fuz
Pro?
There’s a thread on Google Analytics here:
http://www.freewaytalk.net/thread/view/31008#m_31009
For Meta Tags go to the ‘Page’ menu > ‘Meta Tags…’ and click on the
‘New…’ button, then add ‘Name’ and ‘Value’ as you need. You should
vary keywords to suit different pages for better SEO, although you can
initially set some tags in a master page if that helps.
Colin
Fuzzy_Z
(Fuzzy Z)
May 14, 2009, 6:39am
3
Thanks Colin - I’ll give it a try tomorrow and let you know how I make out…
~The Fuz
Fuzzy_Z
(Fuzzy Z)
May 15, 2009, 9:23am
4
I think it worked - just waiting to see if I get some hits.
`The fuz
