[Pro] Index page
Hi - Nice to be back and happy new year to you all.
The TH site needs some user edible content on the homepage - it has WebYep attached on another page already so I know thats there and easy to plug-in. BUT and heres my question - Ill need to change the homepage to .php - done this matter being an index page? Also I seem to remember theres a way to parse the php back to html (i’d really like to keep the .html - as I’m sure the client would have sent the whole www.tramolinehight.com/index.html to customers)) and have there server do the parser thing? Any ideas/help/pointers - cheers
Sure. You just need to add a line to the .htaccess file in the same folder (or any folder higher than your index.html):
AddHandler application/x-httpd-php .html
You may need more than just this, so have a read through this page How To Parse HTML Files As PHP – Web Development Blog if the simplest thing doesn’t work for you.
http://www.trampolinehigh.com
Thanks Walter! If you don’t here back from me you know its working :wink:
