[Pro] info css
hi@all, sorry for my english : )
i’m in trouble with a problem. It’s a long time i’m trying to resolveit but i’m getting crazy.
Well… when i publish the pages of my website in the css style, in the tag and , appears height: 100% and i have to chance it. I canched it , in freeway before the publishing, inthe css panel writing heigth: auto, but when i publish it become 100% again.
I should create css external file and modify only this but this solution create another problem so i looking for a solution before the publishing.
thx
brz
Hi brz,
What version of Freeway are you using? is already set to auto
in Freeway 5. If you need to change (and <body if it’s set to
100% in Freeway 4 for example) then go to Page>HTML Markup, select the
"Before option in the dialog that appears and enter:
<style type="text/css">
	head, body { height:auto }
</style>
Can I ask why you need it to be set like this?
the publishing.
thx
brz
Hi Joe, thx for your answer and your suggestion work. Great!!!
I’m using the script ‘IFrame SSI script II- Dynamic Drive’ that allows to resize dynamically to match its content height in iframe. But all the pages published autimatically by FW dont work. To fix problem i mustn’t select the ‘layer’ in the ispector for very elements and change the value of height in body tag in auto.
I choosed the ‘IFrame SSI script II’ because i’m building a modular website (es. blog structure). I tryed to do this using the #include in php (server-side) but it cause the problems with the css and paths. At the end i decided to use FW for the edirting of the contents (like sidebar and main content), and insert them in html structure manually edited. I ask you another info: if possibile to create a main structure in FW? I tryed whit frameset (but i can’t set the fixed widht and center it on teh screen) and with a table (but its to strict and difficukty to modifiy).
thx, bye
