Make an inline HTML box, then, while that box is selected, draw the Exhibeo element over the top of that inline box as a positioned child element. If you are doing this, the visible feedback you need to see is the edges of your “parent” element glowing blue while you draw the child. This indicates that the parent is accepting the child. Normally, whenever you draw a positioned (layer) element on the page, the edges of the page glow to indicate this relationship. You can also re-parent elements by dragging them within the “outline” in the Site pane while it is toggled over to Page view.
