Before I do something fatal, I’d like to check this out…
I’m adding Clicky to an existing site. On Clicky’s site it says to paste the tracking code in the footer file. (I can’t find any reference to footer files in the Using Freeway doc.)
In Freeway, does this mean
opening /Page/Html Markup…
and then pasting the code to After ?
If not - how do I do this? And presumably at this point, I’ll need to do it to every page?
thanks
Their reference to a Footer file is really talking about a page construction method ie with a Header and a Footer.
They suggest that your Footer would be the same on every page - possibly added via an include.
So all they are really saying is that their code should be added to every page of your site before the closing tag.
You can do that vis insert>Page HTML Markup in the Before end Body section if you like
Do it on your Master and it will appear on every page that is based on that Master.
eg - if you are looking at this post on the FWT Website the code would be added after the line ‘Powered by The Mailist’ in the Footer.
Thanks David - that’s sorted it.
