Here’s the best troubleshooting advice I can give you. In your System Preferences (the thing with the pretty gears on it), click the Users and Groups button, (maybe) click the lock and authenticate to access the user controls (depends on your setup there whether you need to do this) and then create a new user account. Switch into that account (Apple menu, log out, then log in as the new user). Open Freeway, and create a new site. See if any of your speed issues exist in that new and very fresh environment. (My guess is, it will run like a JATO-assisted land speed record car.)
Everyone else here is a) not trying to edit your document specifically, and b) not logged in as you with all the fonts enabled that you have (some may be damaged, and this is the only Achilles heel of Freeway that I know of). They’re not reporting this issue, and it doesn’t seem to be widespread, or there would have been more report of it. (I don’t see this, anyway, and I’m rocking a Mac Pro from 2008.)
If this little test shows you the real speed of modern Freeway, then you have some digging to do to figure out what is damaged in your regular user account that is causing this slowdown for you. It may be corrupted fonts or preferences files, third-party software like Haxies or DefaultFolder, or more prosaically, a font manager or corrupted font file. It may also be the document itself, particularly if you started the site in an earlier version of Freeway and then upgraded it with a newer version or versions of Freeway.
Back in your regular account, try creating a brand new document from no template (just blank pages). See if you can get that to stall. If you can’t, then maybe the document itself is the issue, and you can try sending it to support(a)softpress.com for autopsy.
On Apr 25, 2015, at 5:16 AM, Richard email@hidden wrote:
Just the standard fonts.
I run many resource intensive apps on several different Macs, video and audio, and none of them bog down like Freeway 6 does on these same Macs.
Freeway 6 is just not responsive for me. I wait 3-5 seconds every time I copy and paste for example. I was hoping for at least a performance boost in 7, but it doesn’t appear that much has changed between 6 & 7 on the performance front.
So no one else is seeing sluggishness in Freeway?
Thanks.
