Bit of a strange thing happening with my test site at the moment. I am building a new site and on the portfolio page I have 20 projects, each accessed via an image that has a rollover action and Moo:Slimbox action attached to it.
ps - if you could also let me know if you see the right font on the page, mainly in the footer. It should be MuseoSans web font, not Arial or Helvetica.
I doubt that is the reason. I do see 12 errors on the page, all related to missing font resources. You might want to start there.
I can’t seem to copy the list of them out of Safari Web Inspector, but if you enable the Develop menu in your Safari preferences, then pull down the Develop / Error Console menu item from Safari’s main menu, you will see them too.
Once you get those errors cleared, it may shake loose whatever else is wrong, as it’s not reporting an error on page load or when clicking on the link. Also check the naming of the files in question. Make sure that none of them include any illegal characters like a space or a colon or a forward-slash.
On May 31, 2012, at 8:40 AM, SJ-Creative wrote:
This leads me to wonder if I have too many actions on this page? Or can anyone else see why this is not working?
Thanks for your response. I have sorted out all of those errors but it hasn’t cleared the issue. I have also added Juke Box Burgers to the bottom row and the same is happening there … no rollover of slim box.
I have checked all of the file names and they are the same format as all of the other images on the page, so no invalid characters.
Have you got any ideas why the actions have suddenly stopped working for these items?
Check the stacking order of your bottom ‘dividerdiv’ element. It’s currently overlapping the bottom row, and intercepting all the clicks. Also, are you using RPL on this page by any chance?
On May 31, 2012, at 9:19 AM, SJ-Creative wrote:
Hi Walter,
It was the dividerdiv overlapping the bottom, so those rollovers are sorted now, thanks
One quick question, what do you mean by RPL?
Still not sure why only 2 of the 3 UHSU screens are showing though? Can you see anything, or should i get rid of the action and try again?
Relative Position Layout Action.
I would try rebuilding just that one slideshow on a separate page, and see if it works there. I don’t see any errors, so I can’t explain it from here.
