If you create a Tag-only Style with the tag set to td and you deliberately don’t style any of the text on your table at all, then you will see your table text the way you want it – just not in the design view.
On Apr 25, 2012, at 7:13 PM, “Hoffman” email@hidden wrote:
Hi,
is there a way to format an entire table at once in the beginning? For ex. I want each cell to be Verdana 20 centered?
I find I keep having to format 1 cell and copy and paste to others and then change the text.
