Hi all,
new season is about to begin.
I was wondering, my parents are going to fill out a form (I am using PHP feedback form).
There will be a place for them to enter their email address.
Is there a way I can make it so they need to confirm their email by typing twice as you see often hoping they will match.?
I know sometimes they can copy and paste so I could ask them to retype it, but is there anything better and simple?
Thanks!!!
Barry
Rather than a double entry - what about this script?
http://www.javascriptkit.com/script/script2/cmanual.shtml
Looks interesting and a fine idea.
Can you make a small example with this in u use Dave or do you have a link to a page to see this in action?
Barry
Going out just now but I will put one together for you a bit later.
You are awesome.
Enjoy Sunday.
OK - here it is http://www.deltadesign.co/FW7Test/simple-form-check.html
1 - Add the following script in Page>Html Markup in the Before section.
<script>
function alertemail(which){
if (confirm("You entered ""+which.value+"" as your email address. Is that correct?"))
return true
else{
which.focus()
return false
</script>
2 - Make sure that the Name and the ID of your email field are email.
3 - Apply the PHPFF action as a page action.
4 - Go to Page>Form Setrup and under the Extended Tab add the name/value pair of
onSubmit/return alertemail(email)
Note that ‘email’ in here matches the name/ID of your email field.
5 - Upload and test
Thanks Dave,
Look forward to trying it.
I’ll let you know.
Thanks again,
Barry
