Erik
(Erik)
February 18, 2014, 1:36pm
1
Hi Guys, have to make the following in Freeway
Example:
http://roomdresser.ch/index.php?lang=de
choose in menu “Portrait”,
Then at the top below the white text “Philosophie” apaer, when choose this link, html layer apear next to it
So basicly, A parrent Html, with 2 child Html’s
in the first child text links point to the show/hide html layer
Is this possible?
thx
Erik
So is your question ‘Can I have two items that link to 2 different Target Show/Hide layer items’
Yes
BTW that page is all Flash.
Erik
(Erik)
February 19, 2014, 7:20am
3
And then especially Html! and wich action do i need to add to the first (link) I asume the second is Target show/hide?
thx
Erik
Rollover/Text Rollover
You can do this many different ways ie Transition FX to get the 2 links to fade in after x seconds and then Rollover in conjunction with Target Show/Hide to reveal the 2 panels.
Erik
(Erik)
February 19, 2014, 8:23am
5
Thats what I tried earlier but doesn’t get to work,
Gonna try it again, Thx Dave for your advice!!
Erik
Erik
(Erik)
February 19, 2014, 8:44am
6
Hi Dave,
Here:
http://www.kscs.graphicid.nl/services.html
I did exactly (as far as I can see) what you said,
insert text rollover, draw html, add target show/hide layer
do the right setting, Indigo, target 1, etc
but no success, any idea?
curious - for exact this project, I had to make an offer these days (which I didn’t cause I have not time to and many other reasons for not stepping in here).
Erik
(Erik)
February 19, 2014, 10:03am
8
Hi Thomas, everything fine with you?
That’s coincidental, small world we live in
She ask for a rebuild from her own site (but then with a good construction)
Not finished yet but run into small problem (not solved yet)
Maybe you have an idea? improvements
Erik
Yeah - thanks I’m fine.
I’ve honestly not really an idea cause I’m not very used to those actions anymore (I dig more in the coding-mud on other libraries honestly).
So what effect are you not managing - I am seeing the show/hide OK?
Erik
(Erik)
February 20, 2014, 2:09pm
11
Hi Dave,
Everything works fine now!
There was nothing wrong with my construction or actions but it was pure the conflict with WOW slider code.
Placed the code on the master, so every new page had the code in it there it went wrong.
Thx for your help!
