Is it possible to get a time stamp for every time you saved a freeway document? I know it says " modified on" but I want to see all the times I saved the document
Time Machine, browsing through the various times that it captured a different value for the updated at is the only thing that comes to mind. There’s nothing in the Finder or Freeway (which uses Finder for this info) to give you a log of save points. You may want to look at using Automator or just AppleScript to build this for yourself, the trick would be to create an applet you could call (and bind to a keystroke in Finder) that would add the current time to a text file somewhere and then call the File / Save in Freeway.
Save the file to a DropBox synced folder and DropBox will keep track of the save revisions for you. Simply right-click on the Freeway file in the Finder and select ‘Show previous versions’. https://dl.dropboxusercontent.com/u/795566/revisions.png
