Hello, I am experiencing an issue with carousel 2 action. I am building a carousel with the wrap-around option ON. No matter what I do or change, my third (and last) pane always repeats before moving back to the beginning. Any ideas?
Try removing the Actions from all of the elements, publish once, and then re-apply the Actions. You should have three HTML boxes on the page involved in this construction: the first, in the position where the composite element will appear, will have the Carousel 2 Action applied to it. The other two, which may be positioned anywhere you like on the page or pasteboard, will have the Carousel 2 Pane Action applied to them. If you are using the Relative Positioned Layout Action (RPL) on this page, then be sure to apply the Remove from RPL Action to the carousel and the panes in addition to either the Carousel 2 or Carousel 2 Pane Actions as appropriate.
On Feb 6, 2014, at 11:58 AM, LuisB wrote:
Already did but still the same… Check it out. Please let me know if you find anything, I will keep on trying. Thanks again
