I’ve got a couple of items that the checkbox to the left of them in the sidebar has an ‘x’ in it and the item is not visible on the screen. This happened after resizing a different object. How do I get the item to show up again?
freewaytalk mailing list email@hidden Update your subscriptions at: http://freewaytalk.net/person/options
It sounds like this is a non layered item that overlaps another.
Try selecting it to see if it is a Layer or not.
Enabling it as a layer may well fix your issue - or resizing the one that overlaps it.
You can select it from the sidebar to see the settings in the inspector.
