This occurred after I tried installing a Blogger page within my site. I’m not even sure this is possible to do but the Softpress tutorial video didn’t say it wasn’t so I went ahead. At any rate, after checking all the settings nothing seems to be out of place so I don’t understand why these 3 items should have shifted.
No its not.
The Blogger page relies on the server machinations at Blogspot.com which are not available on your site/server.
The tutorial explains that you create a page and host it on your server but this is just a repository for all the Resources (images etc.) that your blog on blogspot can access.
When you follow the tutorial you will see that you copy the FW page code and paste it into the Template Editor in your account at blogspot (where it will run)
You can display the blogspot page on your site in an iFrame but this is really just a window through which you are looking at yourblog.blogspot.com
Right! Many thanks! Will delete the Blogger content and reupload––see if that solves my alignment problems.
Any thoughts on a blog page within the site? The Disqus module seems to be a bit of a mess and I had no success with that. Also found the instructions to be unclear at best.
Yes, I read your answer in the previous post but that isn’t the same as having a blog embedded in your site. I’ll certainly look at pulsecms, though. Thanks again.
