t50ufo1
(t50ufo)
January 12, 2012, 8:54pm
1
I have a page with a Java Script/J Query running (Fancy News) and it is obviously conflicting with Fading Slide Show Action.
I have tried to use an iFrame to bring it in externally but no joy. Other choice was Carousel but that’s a non starter.
I really need to have some sort of linkable slides on there. Can anyone help.
Sample Page is here with the iFrame option in place:
http://www.frazerwarnock.com/test/
Here is a jQuery slideshow example http://www.deltadesign.co/fw_examples/jqueryslideshow.html
t50ufo1
(t50ufo)
January 12, 2012, 9:35pm
3
Hi Dave
Thanks for the example. Sorry, just to clarify. Will this work on the same page as the Fancy News Script at the bottom of the page. I take it I can just use images in the panes?
Your example looks very good - will I be able to add links to the panes?
Thanks once again for the fast reply.
T
Fancy News uses jQuery as well so no conflict.
Just make sure that you don’t load the same jQuery library twice.
You can have any content you like including links.
t50ufo1
(t50ufo)
January 13, 2012, 8:21am
5
Excellent!
And just what I needed to hear.
I will get cracking on it. Again Thanks for your help.
Kindest regards
