I almost forgot my favorite reason for using these services – unlike an e-mail, you can edit them after the fact. I cannot count the number of times I have posted something example-shaped, read through what I wrote (after I sent it) and saw a typo that either altered the meaning or broke the example entirely. I can go back and edit a Gist, and the next person to see it embedded in FreewayTalk will see the corrected version.
True, sometimes there is value in my errors, and pointing them out, and correcting them “in public” with a follow up message. But if a person comes along later, parachuted into the conversation by Google (or the fabulous Sphinx search engine in FreewayTalk.net), then they also have to piece together the real solution over multiple messages in a thread. Sometimes having everything together and fully baked is just nicer.
On Mar 9, 2017, at 5:00 AM, Walter Lee Davis email@hidden wrote:
The Gist (or Pastie) only appears in FreewayTalk after you publish the new post. That’s a long-standing bug that I never fixed while I had the chance, and now can’t fix because I no longer have access to the server.
In my usual use-case, I just paste the URL in Mail.app when I compose messages there, so I don’t see that distinction. The color syntax highlighting is dependent on you setting the correct file type, either by giving the Gist a fake filename when you create it, as I did, or by using the file type picker to choose the programming language. Both of those options are in the Gist interface, not the FreewayTalk one.
In the case of your example, which I just pasted into Gist, the fact that it had tags meant that it was HTML, so I ended my example’s “filename” with .html. That was all the clue that the formatter needed. I could also have stripped off the tags, and set it to .js, and that would have worked similarly.
On Mar 8, 2017, at 11:18 PM, JDW email@hidden wrote:
Walter, I created a Gist but when I paste the URL into this field here on FreewayTalk, the URL does not appear in the Preview! The only way I can get it to display is by putting it inside “code” tags like this:
https://gist.github.com/JDW1/2c2b619fb6bca99fdbfd43d4a4c49b2c#file-gistfile1-txtI copied your Gist’s URL above and pasted it into my post here, but that URL too won’t display in Preview. How in the world did you insert it?
Furthermore, when I view my Gist on Gist Hub, it is not colored. What’s the trick to that?
James
dynamo mailing list
dynamo mailing list
dynamo mailing list
