[Pro] jquery and javascripts?
Hi - Im planning on using the Jquery powered Wowslider - but would also like to use Simple search action, Navigation popup action with I believe use Javascripts?
Will there be conflicts between these? I know I cant use scriptaculous and protaculous actions
Excuse spelling!
J
jQuery can coexist with nearly any other hand-coded (non-framework)
JavaScript code. Unlike Prototype (and MooTools, which is a fork of
Prototype) it does not extend the base objects in the JS language, and
so you won’t introduce errors by including the library within the
context of other code.
If your other JS code defines a function named $(), that will be over-
ridden, but that’s fairly unlikely outside of Prototype or Moo.
Excuse spelling!
J
Phew great thanks Walter - That saves a few head aches.
J
