http://www.cmlmarketing.com/2012/j/jquery.html
Worm
Worm
The problem is with the google api script call. It should be
//ajax.googleapis.com/ajax/libs/jquery/1.8.2/jquery.min.js
Not what you see in the source code
//ajax.googleapis.com/ajax/libs/jquery/1.8.2/jquery.min.js’
I just cant get it to work!!! Im going mad here…
Hi Todd,
looks good to me using safari?
Seb
Yes, Safari. Maybe it’s just me but I’m also seeing ,
type=" text javascript'
should be
type="text/javascript"
Hi Todd,
You need to dumb-down your quotes. You have fallen victim to the formatting engine on this Web site, which tries to nice up the dumb quotes by formatting them to proper curly quotes.
Look carefully through your code. Anywhere you see a double-quote, delete it and type in a plain double-quote, and likewise with apostrophes. Likely you will be replacing a properly-curled typographer’s quote with a straight-up-and-down “typewriter” quote. Any CODE that includes curly quotes will utterly fail to run correctly.
Change the following:
to
That’s what I did to get it to work.
HTH
Mike
Worm
It works!!!
The problem is with the google api script call (’) after .js:
Wierd as this was NOT at all visible, only showed up in the source code!!!
It should be
Thank you all, now for some tweaking!!!
Worm
Good news!
Strange I couldn’t see that in web inspector.
At least it’s sorted now…
Seb
I’m glad I wasn’t losing my mind, I knew I saw it in there.
