Hi. When I place white, normal weight text on a dark background, it looks perfect in FW, but renders much heavier in browsers (the text is definitely not bolded), while dark text on a light or white background views as it should. I read up on this and it seems to be a function of browsers, but is there something I can do in Freeway (or outside of FW) to prevent this from happening? The site would look significantly better if the text rendered as it should (lighter weight). I’m using standard Helvetica Nue.
Thank you.
