[Pro] Lightbox2 integration
hi there - is anyone able to help with using Lightbox2 -integrating the code - from http://www.lokeshdhakar.com/projects/lightbox2/ which gives a very nice forward backward button and a descriptor? I’ve looked at Walter’s action which is so easy to use! But really need the darkening background and all the above as mentioned! I hope you can help - if there is an action that offers all this I’d be happy to pay but I can’t find one!!
http://www.coastalrugs.com/Actions/mootoolssuite.html
Op 18 aug 2009, om 17:36 heeft Richard Knight het volgende geschreven:
FYI. Weaver’s lightbox does NOT work with video. There are also conflicts using mootools with Scriptaculous actions.
Hi there
I’ve been using Weaver’s Lightbox action successfully on many sites. I wanted to add the now freeway Mootools Actions Suite but when I install it the Lightbox Action is disabled. This means I would have to re-work all the images the lightbox action had been applied to. Does anyone know how/if these two actions can live happily side-by-side?
Many thanks
Gordon
http://www.gordonlow.net/
thank you for your input, I think I’m going to use Mootools Actions Suite! I’ve also come across this strange site which shows how to manually add Lightbox!
http://freeway.ontwerpzaam.nl/lightbox/
They share some of the same code so they cannot both be active. You will have to deactivate one or the other in the Edit Actions menu and uncheck the action you don’t want active.
