have had this in another list but am not sure if it is noticed.
The line height can be set within the styles palette in percentage. So far so good - but there was once a recommend to do this via extended attribute and the value pair
line-height: 1.5 (as an example)
So far so good - but this is not showing up in Freeway document (… but in preview and in browser view).
Anything put into the extended dialogue windows in Freeway, CSS included, won’t be reflected in the layout view.
Leading, especially if you want to use Percentages, is always tricky in Freeway because it does not always display the leading correctly, nor does it publish it as a percentage.
