[Pro] link style
I’m working on a new project based on a template of soft press in Fw Pro7
I want to change the link style colors with different colors without result.
In the inspector I give the links the right colors (yellow)
Create a new style and added to the footer links (under “categorie” first links, but it becomes purple?
What do I forget?? Do I have to change styles manually and were?
Thx Erik
http://www.sio.graphicid.nl
The styles dialogue is in inspector second (pen) tab, bottom:
Nothing on your page selected will be the link-styles page-wide.
An item selected is link-styles for this specific item.
Preferably select parent items such as #links (or even #Footer-wrapper) to make the links working for the parent and ALL its child-items.
NEVER create styles manually or using inspector fiddling - and yes, I’m pretty sure that this is even part of the Freeway manual, billion times asked, though. I suppose nobody reads it.
I am sure, that this theme has link styles already done this way. Click through a couple of items and check if you can see them.
Another thing to note:
Go to Font-Sets dialogue (via edit). In the opening dialogue, head over to the alternative fonts list and REMOVE all semicolons that you find at the end. It’s a known issue which is already addressed but not done yet (I suppose)
If you want to change the link colours in a CSS Menu then your text should start unstyled and ONLY make the changes in the Links part of the CSS Menu action.
Thank you both,
Found them :slight_smile:
